Discuss Drayton tempest three control panel in the Plumbing Jobs | The Job-board area at PlumbersForums.net
F
Funkyboy123
Hi All,
I've got a Drayton tempest three control panel that must over 20yrs old. It now needs changing. can anyone tell me how you get the panel off so I can get access to the wiring? There's no screws around the side or obvious clips anywhere.
Anything like the new draytons, should be two screws underneath on the bottom face (you won't need to undo them all the way just enough to pop the controller off) and if you can take a pic of the backplate I'm sure there stnd but can't be sure until I have a loo
There no screws anywhere just can't see how you remove the panel. I've seen online the new panel does have screws underneath but not the old Tempest Drayton Three
Managed to get it open will this back plate fit a new Drayton?
Yes should be but if not looks like a straight swap
Turn power off and swap wires over to new backplate like for like
Was it just the tilesholding it in place? Looks like the screws are missing. Because of the tiles!
Reply to Drayton tempest three control panel in the Plumbing Jobs | The Job-board area at PlumbersForums.net
  • Sticky
