Discuss double radiator in the Plumbing Jobs | The Job-board area at PlumbersForums.net
beefamurkin
ive been asked about a double radiator which only heats on the front, he can get the back of the radiator to work by turning the trvs off upstairs as if forcing the water through, this only lasts for 2 to 3 weeks though before it happens again. anyone any ideas ?
Hi try balancing the system using the lockshield valves. (turn L/shields of and just open say one turn also check if pump has a higher setting but be aware might start pumping over. Monitor results. Good Luck
Is it possible that the front panel is getting sludged up? I've never come across it in just one panel but it could be.
Mark.
Reply to double radiator in the Plumbing Jobs | The Job-board area at PlumbersForums.net
