Discuss Double check valves and high water pressure in the Plumbing Jobs | The Job-board area at PlumbersForums.net
stratplus
Came across a few Double check valves failing recently. Washing machine no water errors and outside tap with long hose connected same no water. Remove hose and open tap water flows ok. Re-connect hose ...no water. No blockage, no kink. Replaced washing machine valve to one without check valve and problem solved. Water pressure to property shows nearly 7 bar static. Pressure linked to check valves not working/locking up? Took hose off Washing machine and ran into a bucket fine, reconnect and locks up again. Changed 3 so far due to these issues on different properties. New valves too. Anyone came across this?
Reply to Double check valves and high water pressure in the Plumbing Jobs | The Job-board area at PlumbersForums.net
We have a utility room with a washing machine but no sink. Wife wants sink. There is room to fit one and the waste will connect to wahing machine waste but the problem is in the water supply. Currently there is only hot and cold washing machine hose fitting isolators attached to very short...
Hi, all. I have a leak problem behind the washing machine. It's a pipe that is leaking directly into a drain. It used to drip but now is leaking a steady stream without stopping. Seems to be coming from water heater but I cannot tell. It is cold water. When I turn off the main water supply, it...
Pritesh Patel
Looking for any ideas to help. I've a Heatrae Sadia Hot Water tank, heated through Oil fired boiler (working fine). A week ago I reset the air gap as I was having dripping from the pressure relief valve. Since then I've lost a lot of pressure from the hot water feed to my shower. The rest of...
Hi My washing machine is 5m away from the water mains copper pipe/valve. I've currently got a long blue inlet hose connecting the washing machine to the copper pipe/valve. Is this OK or should I get more copper pipe added and then use a shorter blue in let hose to connect the 2?
Hi all, Got a strange grating noise when the mains water is running in a property I'm looking after. It's a ground floor flat, with a first floor flat above it, and both share the same mains water pipe, and I believe the stopcock behind the washing machine isolates all water to both properties...
