Discuss Does anyone use an angle drill? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Scott_D
Subscribed
Any recommendations?
I have Makita stuff so looking at the keyed and keyless 18v
That's next on my list. Currently just use an Irwin angled bit which doesn't quite cut it. The bare 18v Makita angle drills ain't too bad price wise.
will update you in a bit :D
you seen the 36v makita angled drill?
They are bigger than a non angle drill.
Surly,then what’s the point in
That one I posted will be the extreme you can get smaller ones hole hawg
I have the 240 volt Makita angled drill and it is good, particularly for holes through timber for waste pipes, on the rare occasion it has to be done
Is it a keyed or keyless chuck?
Old fashioned keyed chuck.
Had it for a lot of years now, but still brand new condition as doesn’t get much use.
I know there used to be 2 models of Makita angle drill at that time - the better one had the handle up at the chuck, which makes it much easier to push the drill while it drills
Stubby impact driver with a flat bit or auger does me for a pipe or cable run through joists, stops with all that wrestling plus I don't put up timber framed buildings very often. ;)
I'd be lost without my angle drill . I use it loads .
It's Makita 240v I have but I've been eyeing up the Milwaukee beasts but reviews have been very mixed.
Hole hawg ?
Yeh the hawg that's the beast
I have the Milwaukee M28 which is really good . Had it about 12 years, still going strong.
I also have a Milwaukee M18 hole hawg, the smaller one. Very good also, better than above with spade bits due to higher speed.
I also have the larger Makita 110v one which has a 2speed gear box. Can do 6inch holes no prob.
The flexvolt looks good.
Keyed chucks are better for the torque of these drills
Reply to Does anyone use an angle drill? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I am currently doing a new build requiring 2 shower trays to use as walk in showers. The tray I currently have does not appear to have angled rims around the edges so water constantly pools at the sealant and doesn't run into the tray and drain. Can anyone recommend d a tray that does have...
Have any of you guys used this type of shower trap? It’s not 2 compression knuckles like most it’s more of a swivel fitting to give an angle. It doesn’t unscrew either.
Think I know the answer is no but asking just in case. I have a solvent weld bathroom waste with lots of connectors in it that disappears into the wall with a right angle connector. There is no place to break into it to connect up a new arrangement for a new sink. So does anyone make a...
Engineer has installed several boilers for me. All the condensate pipes have been connected externally into soil stack or rain water downpipe. In each case he just drilled a hole in the pipe, and stuck the condensate in the side, smeared glue everywhere. No boss, or branch. Is this allowed, is...
I've got an issue with the shower tray not being totally flat. As you can see from the photos, it is about 7mm out at one side. It's leaning towards the waste end though. The shower tray is pushed underneath the tiles. My mate did the tiling and I now realise that we should have put the shower...
