Doc
Discuss Doc in the Plumbing Jobs | The Job-board area at PlumbersForums.net
rocketmanbkk
Can anyone tell me what the difference is with type A & B DOC's please
Thx
Rct
the retainer
a
b
The retainer on type b is bigger?
So, what do you use most?
I used a type a today on a rad drain.
Tbh, I didn't know there were type a & B!!
no b doesnt have a retainer you can unscrew the shaft all the way out
a you have to remove the retainer to remove the shaft
Ah, I see, Thx Shaun
The top part, thx, where the washer is located.
Any pros or cons?
Anyone better to use?
Thx again
Any pros or cons?
Thx again
not a problem and yes a dont leak when fully open
i only fit a
A type drain cocks have a seal on the shaft which stops, in theory, water running past the shaft when you use the drain. As far as I know they are regulation to use on cylinders etc inside homes
I use type A Ive got a hole tilt bin full of them as I always get plenty when doing a boiler swap but only ever end up using one or two half the time
Reply to Doc in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Can anyone please tell me where I might purchase a 90° bend 15mm x 22mm Isolating Valve Thanks and Regards. Hugh
Could someone tell me what this is, please? (coming from a Joule Cyclone unvented cylinder) It was making a distinct knocking, vibrating, rattling sound, I turned it slightly clockwise, and the noise stopped instantly. The system is 2.5 years old. is there something I need to do to prevent...
Can anyone tell me where the feed for the water comes from that feeds into the bottom of this Ventair?
Morning everyone, if anyone could please offer advice on this issue it would help me with a massive issue regarding the water supply in my flat. My flat kitchen and bathroom was always on mains supply (no tank supply at all) and the rest of the 5 flats were mains supply to kitchen and water...
