Discuss Do white towel rads kick out more heat than chrome? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
WaterTight
Subscribed
Flomasta 1500 by 600 in white has 50% more heat output than the same in chrome. Never noticed this before.
There is a big difference on most manufacturers - although I would have guessed closer to 25% - 30%
Yeah on closer inspection it varies a lot. Just huge difference on that particular line.
Chrome will reflect more heat, the darker the radiator the more it heat will absorb, making it give out more heat. The best colour in theory should be black radiators, cant se that yaking off in most houses though.
That's why you never see chrome exhausts, they don't dissipate heat very well.
Reply to Do white towel rads kick out more heat than chrome? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I have just moved into a late 1990s new-build house with a small bore (about 1/2" OD pipes) gas fired boiler central heating system. All the normal radiators get hot but two of the three towel heater/radiators don't get hot and the pipes feeding them are cool to the touch even after the boiler...
Hi - I'm a reasonably experienced DIY plumber but just can't work out why the last new rad I've installed is cold - would really appreciate your help please. I've extended an existing 'run' of radiators - the last one on the run ( in downstairs kitchen) is cold. The first rad added is...
Hi all. I noticed this winter my living room rad only get hot in the top half. Radiator is 1600mm(DP SC) double panel single convector. System was flushed just last year. Both flow and return values are fully open and don't stick. Boiler is serviced each year. Baxi combi boiler about 8 ton9...
Hoping somebody can help, So, in a nutshell… Standard 90s Westbury home – condensing boiler, pump, wall thermostat, etc etc... Normal, common or garden, run-of-the-mill British housing estate CH setup. Downstairs radiator, 1 of 2 in our living room, went cold one evening mid-November last...
M
Hello, We’ve recently moved into a fairly old, fairly big detached house (i.e. fairly draughty, but not too bad by any means) with a fairly new well maintained Worcester combi boiler. We weren’t convinced the heating was working right and then got hit with a £610 energy bill for the first 6...
MartinPod81
M
