Discuss DIY Guide To Installing a Wetroom. in the Bathrooms, Showers and Wetrooms area at UKPlumbersForums.co.uk.
  1. Ermintrude
    Ermintrude Plumber GSR
    It's tanked the whole room is 1200 high on all walls and shower 1800 floor complete. resin glue between 18mm marine ply and joists, then full coverage of ply face with resin and another 18mm sheet. Impey tray sat on joists with 18mm between joists
  2. Ermintrude
    No. Used a clegg hammer floor dosnt deflect. Under normal use. 6kg hammer came back same as byson pre camber with 75mm structural screed. ( byson spanning 9m - my floor 2.8m) I sealed joint in rest of room with grout but silicone in shower area . It's lasted 6 years
  3. mutley racers
    mutley racers Plumber GSR
    Why do you need to put 2 X 18mm wpb? I thought one would be enough. So bal is the tanking kit to use then?
  4. Whyme
    Whyme Guest
    It must have just peeled from the chalky edge of the travitine then. treat the joint edges with that sealer stuff.
  5. Whyme
    Whyme Guest
    He's a big lad..
    • Like Like x 1
  6. mutley racers
    That's True
  7. Ermintrude
    Old house expensive coaving below. Roll top shower loo sinks and a pallet of travitene
  8. Destroyer2813
    Destroyer2813 Plumber GSR
    So just use paint on tanking as normal on floors and lip up wall as required
  9. Chalked
    Chalked Plumber GSR
    Normal silicone, even good quality will not stick to stone. The curing process it too quick and it then detaches.
    This is the only one I use on stone.
    MAPEI adhesives sealants chemical products for construction
  10. Ermintrude
    That's the crap I used. I bought the buff one.
  11. Chalked
    Chalked Plumber GSR
    Normal mappai? Mappai ac, or lm?
  12. Ermintrude
    From poo fix?
  13. Chalked
    Chalked Plumber GSR
    How long between sealing the trav and siliconing the joints?
  14. Chalked
    Chalked Plumber GSR
  15. Ermintrude
    Ah! Sealed it about 2 weeks before - delay due to holiday !
Loading...
Similar Threads - Guide Installing Wetroom Forum Date
Questions about installing a thermostat for traditional boiler Plumbing Forum Jun 21, 2018
