Discuss Diverter valve in the Plumbing Jobs | The Job-board area at PlumbersForums.net
M
Matty A
Just a quicky
The other day my inlaws had no hot water so they called someone in who told them it was the diverter valve that needed replacing.They got a quote for £190 inc new valve they said it was gonna take 2 hours at £60 an hour and the part was £70 so i went to the plumbers merchants where i get my gear from and got a valve for £35 and i have changed it myself.
Now the problem i have is i drained the system and changed the valves over,i put the new valve in the exact way the old one came out ie Port A to Port A and Port B to Port B and i wired it in the same as the wires on both valves were both the same.
I have filled the system back up and bled the rads but the pump from the boiler is constantly running is there owt i can do?:confused::confused::confused:
Cheers
Mat
Sorry no one seems to have an answer for you matty, did you get it sorted?
kinda
Maybe you can help me
When i boost the hot water sys when the heating is on the radiators go off downstairs this is when the pump is on setting 1 if i turn pump upto number 2 it is all working ok BUT the pump is so noisey i was wondering if there could be air in the cylinder is this possible if so how do i bleed it????
HELP
cheers
Mat
Not sure if it's air but if you have a hot water cylinder there will be a bleed valve next to it on a vertical pipe coming from the heating pipe work!
yes there is i thought that was just to drain down to a certain level for maintenance works think ill try that cheers
Reply to Diverter valve in the Plumbing Jobs | The Job-board area at PlumbersForums.net
