Discuss dimond core drill in the Plumbing Jobs | The Job-board area at PlumbersForums.net
M
macelectrical
Can any one give me the make of the best diamond core drill. i need a new one soon and dont know the best one to get:rolleyes:
Hilti are the best, but don't come cheap. Make sure that you get the correct bits for the material that you will be drilling.
Marcrist make the best core bits the 850 range the redshark bits are best expensive but they are worth every penny. I put mine through a 4" wall and then through some structural cast steel rebar channel without damaging the core i think it might have even sharpened it a tad :).
Amakita core drill is more than capable for everyday plumbing holes up to 165mm soilpipe joints. Makita 8406 - 850W 152mm Diamond Core Drill
£229.00
+£6.00 17h 11m
MAKITA 8406
If your requirement is for drilling through GRANITE and hard material like PORCELAIN TILES then you need ultra thin metal diamond cores to keep the heat down.
http://www.*********.com/jpgs/br3a.jpg
We are ********* and have a solid reputation for providing tile drills to professional installers.
We produce a number of different size from 6mm to 125mm.
6mm, 8mm, 10mm, 12mm, 14mm, 16mm, 18mm, 20mm, 22mm, 25mm, 28mm. 30mm, 32mm, 35mm, 38mm, 40mm, 42mm, 45mm, 48mm, 50mm, 53mm, 55mm, 60mm, 65mm, 70mm, 75mm, 80mm, 85mm, 90mm, 95mm, 100mm, 105mm, 110mm, 115mm, 120mm, 125mm.
However our best selling solution is the BFKMX or Bathroom Fitters Kit Max
Seven drills in five sizes. Split into "Fixtures & Fittings" at 6mm and 8mm the "Service Pipes" at 16mm, 30mm, 40mm for radiators, waste pipes, 22mm bath pipes, body jets, showers etc.
http://www.*********.com/jpgs/BFKMX1.jpg
We have sold thousands of these kits online with ZERO complaints from professional plumbers, tilers, installers, construction engineers, builders and other trades.
[DLMURL="http://www.ukplumbersforums.co.uk/redirector.php?url=http%3A%2F%2Ffeedback.ebay.co.uk%2Fws%2FeBayISAPI.dll%3FViewFeedback2%26userid%3D365drills%26ftab%3DAllFeedback"]PROOF OF SUPERB FEEDBACK HERE[/DLMURL]
Armeg, Rubi, Macrist all provide solutions which cost hundreds of pounds in initial outlay.
Our price band is between £29.99 and £59.99 and a quantifiable cost that can be added to a customers invoice.
If you require tile drills have a look at our extensive product range at the main website
[DLMURL="http://www.ukplumbersforums.co.uk/redirector.php?url=http%3A%2F%2Fwww.*********.com%2F"]*********[/DLMURL]
Reply to dimond core drill in the Plumbing Jobs | The Job-board area at PlumbersForums.net
