Currently reading:
Diagonal Heating Zones!!
Discuss Diagonal Heating Zones!! in the Plumbing Zone area at PlumbersForums.net
One of your heating eg rads is calling for heat eg it shouldn’t happen let’s say if you turn the stats down to 16 once the house is heated
but otherwise normal for the boiler to fire each and every time when heating is called for....so if you set the heating to come on for an hour if it fires up 10 times in that hour it's ok?
Yes as it’s keeping the internal temp to the lost heat
There are ways to control this better the TPone can operate in open therm , check with your electrical contractor I'm quite sure the Baxi assure is compatible also . Google open therm for a detailed guide of how it works and how best to use it . Kop
Heat only
Thanks could you rephrase that with red tank , white tank, left or right...about the level of my experience 😊 so I can point it out to them, thank you...
yes not a problem
White pipe coming out the floor plastic around 11/2 dia
3rd from the right going to the left
Hi Guys, they are coming to fix the diagonal heating zones tomorrow. Please could I have some more info in respect of the white pipe issue above. I attach a few more photos, it looks like 2 bits of plastic pipes stuck together one thinner than the other. Do these photos help you identify whether it is the correct type. Don't want to be fobbed off, so any technical phrases or standards that have been contravened would help. Thanks in advance.
If you lift up the carpet where it goes through you might be able to see how it’s joined below the floor eg elbow
If you see this (wrong) normally abs or pvc
This (correct ) normally polypropylene
Sadly lifting the carpet doesn't help (see photo) but I think it is going straight down, to be clear are you concerned about the material the white part directly above the carpet is made out of? The wider plastic pipe with the logo on it seems like a much better quality plastic, the thinner part with all the marks on it looks like a much cheaper pipe. Sorry if that sounds stupid.
Could you get a torch and see if there’s a fitting down there ?
Also based on the original photos of the boiler and tanks, i don't know if there is anything in the loft, I am guessing not. What type of a boiler system do I have is it Combi, system...etc, I have tried following the diagrams on boiler manufacturer websites but I can't find one that looks like mine....
Heat only
Unvented cylinder and 3 heating zones
Used an endoscope camera...this is through the gap in the previous photo looks like another bit of board followed by a black pipe..
Correct pipe used so that’s good eg pushfit pp
Down, up and hot water cylinder
Now depending on the spec it might be down and up on one zone, master bedroom on its own and hot water
Reply to Diagonal Heating Zones!! in the Plumbing Zone area at PlumbersForums.net
ShowerSmellProblems
