Discuss Deemed Heat Calculation and MCS/RHI for Solar Thermal in the Plumbing Jobs | The Job-board area at PlumbersForums.net
L
LeakyNick
Hi
Anyone out there understand how the heat calculations for the 18p/kWh works for 'deemed' heat input for Solar Thermal and the Renewable Heat Incentive? Does it only require the SAP 2009 calculation Appendix H which looks compare the solar tube efficiency against the dedicated amount of water to be heated by the cylinder? Or is another method used, say a full building load assessment and an estimate of water heating requirement?
Leaky
Right thanks. I'm curious because it seems to me that solar-thermal is independent of the heat-load of the house. Also, if you use the Appendix H SAP calculation, they don't seem to give a good value for calculated kWh from the panels where I know from experience, my panels are giving way in excess of what it calculated and if the under-valued figure is used, I'm not sure the RHI is actually worth it!!!!
Right...and they seem to be playing their cards close to their chest then!
Reply to Deemed Heat Calculation and MCS/RHI for Solar Thermal in the Plumbing Jobs | The Job-board area at PlumbersForums.net
IS IT POSSIBLE TO ADJUST THIS MIXER UNIT? WE HAVE TO HAVE IT TURNED ALMOST FULLY ANTI CLOCKWISE TO GET HOT WATEROUT. THE FRONT PLATE WITH MIRA ON IT PRISES OFF AND INSIDE THERE ARE SOME PLASTIC BITS AND A SMALL CROSS-HEAD SCREW IN THE MIDDLE. THANKS
