Discuss Cutting plastic pipe in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Remember to regularly re- sharpen the blades on your pipe cutters. An oilstone or failing that a kitchen steel. Barrier pipe in particular blunts the blades and they regularly need resharpening or you will struggle to cut the pipe.
Reply to Cutting plastic pipe in the Plumbing Jobs | The Job-board area at PlumbersForums.net
IS IT POSSIBLE TO ADJUST THIS MIXER UNIT? WE HAVE TO HAVE IT TURNED ALMOST FULLY ANTI CLOCKWISE TO GET HOT WATEROUT. THE FRONT PLATE WITH MIRA ON IT PRISES OFF AND INSIDE THERE ARE SOME PLASTIC BITS AND A SMALL CROSS-HEAD SCREW IN THE MIDDLE. THANKS
