Discuss Cutting into a cast iron soil stack in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi
Any ideas on the quickest and best way of cutting into a cast iron soil stack. I know it is going to take a while but have never done it before and have been told it will take a while. So would like advice on the best tools and best way to do it.
Many thanks
Paul
I tend to use a grinder cutting out in sections ensuring that the weight above is well supported. Also make sure that as little as possible goes down the lower section to avoid blockage. Finally ensure you have something sturdy to stand on also as my mates grinder nearly yanked him off a ladder when it caught on the pipe
Cast Iron pipe cutters.
If you don't own a set - see if you can loan, borrow or steal a set.
No mess, no grinding and a clean cut.
[DLMURL]https://www.speedyservices.com/17_0181-h-pipe-cutter-cast-iron-12in[/DLMURL]
Hire a set !!
Safe way to cut it.
Take links out & will cut 3,3.5,4 & 6"
Looking at original post I think he wants to cut into the cast not cut it out I use a starrrett cutter on slow speed no oil or cutting compound only water sprayed on whilst cutting...regards Turnpin:smile5:
RIDGID cast chain cutter, wish I had not sold mine, but never likely to use one again as I push pens and keys mainly now.
Hi
thanks for your help. I need to cut a hole in the pipe to fit an inch and a quarter pipe. Is there a specific drill bit for this
Paul
Lenox bi metal hole saw with rigid cutting compound sprayed on every 30 seconds
I put a 54mm (ish) holesaw through a cast stack the other day.
With an erbauer scukux special holesaw.
Slowish speed plenty of oil (I only had wd40 on me and not a decent cutting oil)
And hey presto.
Easy peasy
I used to use the botch quick release ones. No longer ! As I drilled through it quickly released itself down the stack !
Reply to Cutting into a cast iron soil stack in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I need a quote to replace a soil stack ( cast ) in Leyton e10. The stack is already in plastic at the bottom. There also needs to be amendment to branch to accomodate a change of position of the bathroom in the upstairs flat. BTW - this is one up/ one down flat arrangment. There is access to...
Hi guys, few years off doing the work but I like to plan. Can a soil stack be rerouting away from the house, over an extension roof? Reason to avoid internal stack from ceiling to floor. Quickest 30second sketch attached. I'd presume any horizontal would have to have the appropriate fall, new...
Hi I need to this cast iron pipe back as my new back to wall toilet won’t fit otherwise. Cutting it back i am going to lose the collar. So what fitting can I get for it I would like a flex as it will easier for me when installing the new toilet
Hi Oracles of all things plumbing, I have to replace a cast iron soil stack which is simple enough, done a few up here in Scotland, however, client wants to retain the 3" toilet waste as he does not want an enlarged hole making in a newly rendered wall, which 110 to 75mm fitting is best? trying...
Hi, I live in a house that is 20yr old. There is a single soil stack running from the top floor (of three) through the first floor bathroom and then through the kitchen to the drains. A while back I started to hear a drip hitting the kitchen ceiling (now with some ceiling evidence too) from...
