Discuss Correct adjustment of boiler bypass for thermostatic valve in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I have a wood pellet boiler 25m from house (with district heating pipe). The pump is at the boiler on the return pipe. To prevent pumping cold water to the boiler when the pump starts there is a thermostatic valve (Esbe TV RL-72) installed as shown in the instruction leaflet na.heating.danfoss.com/PCMPDF/ESBE_TV_instructions.pdf with a 1/2" gate valve in the bypass circuit (port 3 on the diagram).
Code:
 to house        |               |               |
                 |   bypass      |               |
                 v_| gate        |  boiler       |
                 ^ | valve       |               |
                 v               |               |
>--------------->o<-------(P>)---+               |
 from house     TV               +---------------+
The problem: on starting the pump it's taking up to 30 minutes for the circuit to get to the stage where hot water is flowing properly to the house.
The question: what's the correct procedure to adjust the bypass for best response time?
Reply to Correct adjustment of boiler bypass for thermostatic valve in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hello, my Mothers heating failed in the recent UK cold snap. I found the pump was stuck. I have a question about pump orientation. The existing pump flows downwards. The manual for the proposed replacement recommends that it should pump upwards. This would involve rearranging the flow &...
 Our heating stopped working today. We've got a Veissmann boiler that's under a year old, and an older Megaflow cylinder, and two diverter valves (all about 10 years old). We also use a Hive thermostat.
 When I boost the hot water with Hive, the receiver near the boiler shows it's...
T
Please advise me. I am a disabled pensioner. I had a wet room fitted just over a year ago using a local authority grant. Builder was employed by local authority. I had no say in who carried out the work. I have called the builder out under the guarantee several times for water leaks. The shower...
TheCatWhoNeedsaHotShower
T
A
I have a UFH manifold from Wundatrade with a Grundfos pump. The pump feed has a mixing valve which has a hot inlet from the thermal store, and a cold inlet from the return manifold. In-between the mixing valve cold inlet and the return manifold, is a tee which returns the cold water to the...
3K
We live in a 1980s four-bedroom detached house. The time has come for new central heating. The current system is a mild revision of the original heating installed when the house was built, and this revision was largely to replace a life-expired boiler: non-condensing fan flue boiler open...
2K
