Discuss connecting to lead waste in the Plumbing Jobs | The Job-board area at PlumbersForums.net
H
-=HaZ=-
Hey guys, been working on a job plastering and they have asked me to put the bathroom suite in, when taking the old one out it was all lead so iv cut back on it all to the wall and will install new waste for the sink and bath
My issue is the toilet isn't in the same position but its about 4ft away so I might have to drill straight through the wall....
Either way iv got to connect to lead pipework, either on the outside of the building into the drain work that's there now or through the old waste
What is the best way to connect to lead and what fittings would i need? Also the pipework is needed for the toilet, so it will be approx 110mm
Reply to connecting to lead waste in the Plumbing Jobs | The Job-board area at PlumbersForums.net
As part of a slow DIY bathroom refit I've removed the old toilet from the original location next to the soil pipe (and obviously capped off the branch) and plan to place it the opposite end of the room. I was pretty lucky to find a 110mm sewer waste pipe below the old sink which is the new...
Hi all I really need some help or advise….. Back story….. Some years ago my dad had an extension to his house which included a newly built downstairs shower room. Recently he had this downstairs shower room re-fitted/decorated. Quite a simple set up consisting of a sink, toilet and shower...
Hi all, I have an old toilet on the top floor (to be removed) which empties into an outdoor vertical SVP and into the ground. The pipe is straight with a vent terminal on top. Another toilet on the ground floor empties through the suspended timber floor into (what I suspect) a drain. I wish...
Hi all, grateful for your expertise on the following. DIYer, not pro. Rural property in France Single storey. Septic tank. Late 80s construction with concrete slab subfloor. All of the waste pipes run in the concrete, and exit the property at the chamber as pictured, just outside the building...
Hello hello,, Hoping there are some experts or experienced Bulgarian plumbing chaps in this site ?. Here in the UK I can fit a bathroom just with the experience I have picked up over a lifetime. I can make copper pipe runs isolaters taps sink shower etc but me and the missus have bought a small...
