Discuss connecting old copper pipes in the Plumbing Jobs | The Job-board area at PlumbersForums.net
babbster
i have recently had to fix a leak on a section of old copper pipe. the pipe is slightly bigger than 22mm and is thick enough to have had a thread put on it. any ideas how to replace a section with 22mm copper?
there has been mention of a transitional coupling, however this a DHW pipe
it is probaly 3/4" copper you can get 3/4 to 22 soldered
couplings
It might be the really really old stuff before 3/4
It was more like 1/2" iron for size O.D.
Last time I dealt with it I think I soldered or brazed a female iron to copper on the end of it.
If it is that stuff ( and it sounds like it ) you won't find a manufactured fitting for it.
Use a drift or socket former to create a socket in the end of the old pipe, and then solder 22mm pipe into it.
A drift won't work Ray. It sounds like screwed copper, it it slightly larger than 22mm. Normally found in old high end houses. Nobody makes a transition fitting, and the threads are " fine taper" so BSP is nowhere near. The copper is as thick as galvanised pipe, so great for scrap.
The times I have connected to it, we used a 1"BSP male to 22 mm compression fitting. The 1" thread will slide over the pipe and either solder it using leaded solder ( I know!!) or better still hard solder or braze. Then you have a 22mm compression end to go off.
There speaks a proper plumber. IMHO
Problem what problem !
With his skills & knowledge he can adapt, repair, overcome & only if absolutely necessary replace to fix the problem.
Every day's a school day! I don't think I have ever seen that type of pipe.
i have never come across that size or type of copper before must be from the 40's or 50's ?
This is the only image I can find on google. This pipe is brass, but it's the same for copper and they have brass fittings.
Thank you
will give it a try tomorrow, exactly as you said, old high end house
Came across this pipe in the Leicestershire area (if it's the same stuff). Heavy gauge copper, screwed. It's called 20-gauge and you can buy compression and end-feed transition couplings for it. The end-feed couplings are brass and cost a fortune but it means you can convert to 15mm or 22mm and weigh in the old stuff...
Reply to connecting old copper pipes in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi, I'm trying to connect 3/4" copper to 22mm copper in an old house. However it appears that the 3/4" is actually slightly smaller (measured at 21.1mm) than it normally is. This means I've been unable to use the special 3/4 to 22mm compression fittings as the olive is just too loose...
Hi I've had to cut hot and cold feed to re route for bathroom feeds. The 22mm Copper pipe hot feed is slightly smaller then my 22mm Copper. Solder fittings just slip over it and are really loose so I gather this is old imperial pipe, so I shall use a 3/4 to 22mm coupler. However on the...
Hi, I am probably being unduly paranoid here but I noticed under our kitchen sink that there is some corrosion evident on a small section of copper pipe between compression fittings on the hot water feed. There are take offs for an outside hot and cold tap together with isolation valves and...
How safe are flexi pipes my toilet cistern has one it was changed about a year ago when the toilet was removed for some work to the bathroom floor. However would it be better if replaced with copper pipe. What is the life time of flexi pipes, has any one had experience of them failing.
Hi, hope all is well! I’ve fitted a compression cap on two of my shower mixer copper pipes (15mm). One of them has scratches and burring and is very slightly out of shape. It leaked but I added some PFTE tape over the olive and it seems to of done the job. However… I’m tiling the wall and...
