K
kc1
I need to fit an elbow to the end of a radiator... (no valve needed, the valve is on a manifold)
Simple but untidy option:
use 1/2"M to 15mm coupler, then a short bit of pipe to a 15mm to 15mm elbow
A possibly better option would be to screw a 1/2"M to 15mm elbow straight into the radiator - however in order to get the alignment of the elbow correct, then invariably the elbow won't be fully screwed in tightly.
Is it wise to have the 1/2" connection not fully tightened? Any better suggestions?
Kevin
Kevin
