Discuss Connecting Accumulators in the Plumbing Jobs | The Job-board area at PlumbersForums.net
W
Wayne Campbell
Hi Guys , Looking for an answer we have to fit 4 x 1500 l accumulators (minimum door opening) to our log boiler should they be connected in parallel or in series ?
Cheers
mfis are where youll get the right answer, one heck of a lot of hot water!!!!!!!
Reply to Connecting Accumulators in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi guys What connection goes on to the part floats please? It looks like it should be a compression to me rather than tap connector? I’ll add a pic Cheers
Hi all, I wanted to ask a general question about an underfloor heating system our plumber is proposing and if this solution will be sufficient to heat the rooms. We have only a woodburning stove (15kW nominal output) that heats our open plan lounge/kitchen/diner directly (6.5kW from the...
Hi I have a 22mm hot and cold water supply to new bath. The pipes finish with compression valves. I need a 500 mm tap connector hose to connect with half inch thread on the new bath tap. All the connectors at the main plumb merchants are 22mm x 3/4 inch. No one seems able to answer question...
Hi all, we have a water circulation pump to bring hot water from our woodburning stove and send it to a thermal accumulator tank. We've just started our second season and it's broken. I thought these were meant to last 10 - 15 years? We don't have a domestic water supply - we use water from our...
Hi all, I would really appreciate your eyes on these pictures - What do you see ? Does anything look strange about the Rockwool insulation to you? I suspect that my long ongoing rotting veg/sewage smell is caused by a fault in this connection that has been hidden from previous inspections...
