Discuss Connecting 36mm to 32mm waste pipe in short distance in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Pluminthedunny
Hi
Just wondering if someone can help with the following.
I have a 36mm waste pipe coming straight out of the wall below a small hand basin, to which I want to connect a 32mm pipe from the basin trap. Fairly straight forward you might say - use a multifit or universal connector. However, the space between the sink trap and the waste pipe is about 2 inches max.
Any suggestions for a product or something I could do to fit this? I was thinking maybe a combined push-fit/solvent weld fitting - the 36mm pipe is a solvent weld pipe I believe - but I can't find anything on the market like this.
Many thanks for any help
Chris
can you not cut one of the sections back slightly and install something like this?
Thanks - unfortunately there just isn't enough room for one of those.
After way too much research on t'internet and blank looks from the first plumber's merchants I visited, the second suggested a McAlpine part, which is part solvent weld and part chrome compression fitting which I should be able to fit over the outgoing waste after some wall 'adjustment.' Thanks for your help!
Reply to Connecting 36mm to 32mm waste pipe in short distance in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hello all, Iā€™m replacing a concrete paving slab patio in the back yard. The original patio used 50mm deep concrete slabs on hardcore & sand. Iā€™m planning to pour a 100mm deep concrete patio on 100mm hardcore. In order to achieve the same final height to line up with the rest of the patio, I...
