Discuss Condensate Leak in the Plumbing Jobs | The Job-board area at PlumbersForums.net
R
Roundthebend
Working on a
Ferroli OptimaxHE Plus 25S ( I know )
Condensate dripping from the bottom of the condensate trap. Seams to be leaking from top of condensate trap. Not the pipe from the condensate tray.
Condensate from collector tray, goes into top of an inverted U. Bottom of one leg removable filter. Bottom of other leg to condensate drain.
At the top of the inverted U seems to be a removable plug.
Any ideas don't want to get a new trap to find the same problem.
Reply to Condensate Leak in the Plumbing Jobs | The Job-board area at PlumbersForums.net
    • Useful
My parents have a leak from kitchen sink. My dad removed waste trap and since refitted it leaks, but there wasn’t any kind of seal on it, I got a rubber/plastic gasket that seems To fit the trap but with it, I can’t get it to screw and lock back on (has lugs so locks after quarter turn. But...
I've got an issue with the shower tray not being totally flat. As you can see from the photos, it is about 7mm out at one side. It's leaning towards the waste end though. The shower tray is pushed underneath the tiles. My mate did the tiling and I now realise that we should have put the shower...
Hi all, I have a couple of leaks coming under shower tray downstairs. One is along the wall so think might be joint between wall and tray and the other seems to be near waste tray, there is a slight hairline crack in shower tray near waste . This happens when I leave the shower head near the...
Our boiler is in the loft and I encountered a leak in a roof above our side extension store room which has transpired to be from the boiler condensate pipe. It was cracked at an elbow so the plumber we use has replaced this and hopefully all will be well with that joint. This later prompted me...
Hi, As per title we have a regular smell from the shower trap. Clean the trap twice a week, had a cleaning rod down the shower waste pipe and no blockage. Used several different drain cleaners over time but smell returns (not always but often enough to be annoying). Seems to coincide with...
