Discuss Condensate Drain in the Plumbing Jobs | The Job-board area at PlumbersForums.net
W
witheveryone
What products do plumbers generally use when terminating the condense drain from a condensing boiler?
Strap on boss to soil stack or rainwater downpipe / Waste connection to 40 or 32mm / straight or P traps?
Does anyone ever use an air break or check valves?
Any info would be appreciated! ;)
It can run into a tundish and down a 32mm waste to a drain. :)
Thought condesate must terminate over a grated draincover...no air gap required in it's length...(if it is'nt connecting to a waste pipe which i'm sure is perfectly ok.)
Reply to Condensate Drain in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi, Can anyone advise as to why the cold water to my bathroom keeps airlocking? This originally happened about 12 months ago and has happened 3-4 times since. Itā€™s an upstairs bathroom, fed from a tank in the attic. The tank is about 8 Meters away and feeds a bath, sink and toilet. The tank...
