Discuss Compression stop ends in the Plumbing Jobs | The Job-board area at PlumbersForums.net
C
Complete novice
Hello all,
I am trying to remove a radiator so that I can build a wall in the living room. Drained the system, removed the radiator and now I am a little stuck now that it's come to removing the pipes sticking up from the floor.
I was told this was a simple job of cutting the pipes as close to the join and popping on some 15mm compression caps. So I bought the pipe cutter and caps, lifted the boards and was met with what you see in the pictures.
My question is, where am I supposed to be cutting the pipes? I cannot see a joint apart from where they are connected to a plastic/rubber tube.
Any thoughts? And thanks in advance
https://www.dropbox.com/s/1kfu711fjwnvw2z/20151027_194337.jpgdl=0
https://www.dropbox.com/s/dqcymlc2e544uyd/20151027_194351.jpg?dl=0
https://www.dropbox.com/s/up73abdmh4aww4t/20151027_194402.jpg?dl=0
https://www.dropbox.com/s/fpjw02wk1a3k70h/20151027_194423.jpg?dl=0
https://www.dropbox.com/s/4f4p4rkbd28dim8/20151027_194501.jpg?dl=0
Cut the copper 6" past the plastic push fit elbow and put the stop end there.
Please register with us to receive additional answers to your question.
Reply to Compression stop ends in the Plumbing Jobs | The Job-board area at PlumbersForums.net
OFFICIAL SPONSORS
OFFICIAL SPONSORS
