Discuss Combo boiler shower mixer ??? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi guys - I'm new to forum - I have a question-
I have a combo boiler and directly above is my bathroom - where I will have a shower mixer tap and bath tap.
Hot water to both sink, bath and shower is 15mm from boiler -
Question is - is it ok to run my cold water from the mains - which is a 22mm pipe - will my shower mixer handle it? Or will I have to feed a water tank in roof and make gravity fed? Appreciate any advice -
Cheers
Water coming through boiler and mains should be nigh on identical unless you have a ridiculously high mains pressure then it might be worth a pressure reducing valve on your incoming mains to balance the property and protect your boiler. Maybe get it tested if you believe this to be the case
Great cheers mate!
Reply to Combo boiler shower mixer ??? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Looking for any ideas to help. I've a Heatrae Sadia Hot Water tank, heated through Oil fired boiler (working fine). A week ago I reset the air gap as I was having dripping from the pressure relief valve. Since then I've lost a lot of pressure from the hot water feed to my shower. The rest of...
hello all, happy new year! i hope i have posted this in the right section i have a shower bar mixer. the shower runs luke warm. a quick google search showed some ideas on how to adjust it. i tried adjusting it and it didn't change the temp. when i adjusted it the other way to test the cold...
1K
We have a gravity fed hot water system in our the house we have just recently moved into. It works fine with the downstairs shower, however we are about to upgrade the upstairs bathroom and are considering installing a shower bath. My concern is that although there is more than sufficient...
Hello, and thanks for taking the time to read. I'm trying to work out if the idea I have is practical? The water pressure in my newly renovated house (4 bathrooms is tragic). Current set up is: A hot/cold mixer in the main ensuite which is ok as long as you don't run anything else. One electric...
When I turn on the shower or bath, initially the pump runs (quite loudly) and only a trickle comes out. I have to alternate turning on the bath and shower before I get a reasonable flow. Then once it is running, if the water is at maximum temperature on the mixer it flows smoothly, but as soon...
