- Messages
- 10,444
Unless he is a contractor!Hope he didn't do it on the side as he's not qualified out of work time
Discuss Combi boiler installation in the Plumbing Jobs | The Job-board area at PlumbersForums.net
What type of boiler make is it? I know the logics only need a 15mm gas run. I'm assuming it was gas rated and had all the pressures taken when it was commissioned.
Pipework isn't great but depends what was on the quote to start with, sometimes I would like to repipe everything in properties but you can only do so
ipe to the biliiler is a 22mm connector??
Pipework isn't great but depends what was on the quote to start with, sometimes I would like to repipe everything in properties but you can only do so much.
All combi boilers 22mm from meter if 15mm connection on comb then 22mm to within 300mm of connection
I bow to your superior knowledge, because it makes sense. The "Gas Safe engineer" who told me 22mm back to the meter was spouting Rubbish, then. No surprises there. I didn't employ him as he seemed only to be interested in spending as much time and money on the installation as possible.Just not true. You can work out the size of the gas run and sometimes 15mm will suffice. Although blindly putting in 22mm will cover yourself most of the time.
Reply to Combi boiler installation in the Plumbing Jobs | The Job-board area at PlumbersForums.net
