- Messages
- 34,244
- Solutions
- 3
There's been a few complaints with the 27 not being man enough/ not enough flow
Think one was from @king of pipes
Discuss Choices: Worcester-B CDi or Si or other compact combi? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I remember that. Think he has fitted one at his house and said that he should have gone for the bigger one.
Did you fit their stat as well KOP?Atag ic economiser 27 is big enough for a flat i fitted one for myself with the one control smart thermostat, i am now fitting them as my top end boiler install, Intergas is a close second great value and very versatile boiler both with long warranties good luck with your choice. Kop
Concrete floors mate?This isn't a house - it's just a 75sq metre flat. Not much to heat, and just a question of running a bath.
I thought that you said is it was a flat? 2nd floor?No - wooden floors and on 2nd floor. It's generally not cold, since heat rises in the building.
I am now confused?Bison beams or pre stressed panels mate
Look at the Vaillant ecofit pure
So is the ecofit. Untested that is. No known problems with the Vaillant though as yet and I would take Vaillant over Baxi any day at the minute. Waiting for the 600 to be on a flyer before I try my first oneAluminium heat exchanger on the Pure. The Baxi 600 is stainless steel plus some brass parts and copper tubing. Mind - it's still untested for reliability since it just came out.
The slim ATAG is the same boiler but uses a remote expansion vessel.
The 27 economiser will give the same hot water as all the other 30kw combis (you get 3kw free from the heat recovery)
You offering mate?Have you found an installer?
Not so much under powered shaun it will produce 12 litres a minute at 35 degree rise about the same as its competitors and has a pre heat feature , i added 10 litre a minute tap areator to my bath tap and 8 litres a minute to the shower and basin and kitchen tap water is piping hot even with a 5 degree incoming temp it did struggle a bit at full flow but it was 16 litres passing through it , probably would have fitted the 35kw but i can live with it .There's been a few complaints with the 27 not being man enough/ not enough flow
Couldnt afford meYou offering mate?
The ATAG does not have a built in vessel. Just remember that. So you will need space for a vessel somewhere.No firm decisions yet, but I think I'm going for a slimmer depth, under 300mm. ATAG or Vaillant EcoFit or Baxi 630. All pretty new models so feedback isn't plentiful, so it's good to have some opinions here.
Reply to Choices: Worcester-B CDi or Si or other compact combi? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
