Discuss Changing 3 Port Valve On Bungs in the Plumbing Jobs | The Job-board area at PlumbersForums.net
After a bit of advice please. System is completely conventional OV, 2 tanks, 3 port, etc.
Firstly, is it possible and advisable to change the 3 port valve on f & e bungs?
Secondly, I have the conical, rubber bungs, but the outlet for tank has splines in it. How can I get good seal with these bungs?
Lastly, any tips and advice re. bunging and changing the valve would be great - to avoid a tsunami! :bigcry:
Don't want to stat the obvious, but wouldn't it be quicker and safer just to drain down? You will still have to bleed the system after using the bungs! :confused5:
use a lump of plumbers mate in an old flannnel, you can manipulate it into the right shape
Ive never really understood the fascination with bunging the system. Drain down takes no time at all.
Really? I use them all the time and if your careful they are much quicker then draining down, plus you don't have to reload the inhibitor.
I use bungs all the time too, some systems lock up just like that and them some you wonder why you didn't just drain it! 3 ports can some times be a pest because you have 3 open pipes where the air lock can break. Make sure you have everything you need to install the new valve to hand.
If you aren't confident and it will cause damage if the lock breaks then just drain it.
I see the advantage of bungs but personally I drain down and give the system the benefit of a flush whilst doing the work
Bung it all the way, specially if its a old system, don't want any crap sucking down the cold feed from the bottom of the F & E tank now, oooooo the panic on the faces of plumbers when they try to fill up and nothings happening
Same. Usually bung it, turn off top pump valve if gate type to leave 2 open ends. Crack nut on valve and into a bag. Usually about a pint. Much quicker than draining.
Although I've seen some lads trying to bung 2 floors to change a heat exchanger on a Fleixicom. Told him not to. Sooooooo funny
Thanks for your replies. It's an ancient system that's been added to over the years and has been a real problem with airlocks in the past. I would like to bung if I can.
With bunging the F&E outlet and the splines, would a carrier bag over the bung work?
Any other tips appreciated. Thanks to all.
I find it doesnt take that long to drain and swap a valve on most systems. As soon as I hear it gurgle past the pump etc then whip valve out change nuts put new in wallop inhibitor in the f and e although not much water would of been drained turn water back on, by now my cup of tea will be the right temperature so slurp my tea whilst bleeding the pump and thumb vents in airing cupboard turn on and test. usually 40mins to an hour.
I look at the cold feed and vent before I give my price as alot of the time it is that that gives the most problems with airlocks.
Bungs my bum, a 3 post valve is a pig to change normally, where did this bung bit ever come from, what the hell is wrong with draining down, air will get in somewhere and let water out its not for the DIYER.
If you get air locks when you fill up there is something wrong in the pipe levels, get it fixed once and for all, usually in the roof on the CF from the tank out of level, poor plumbing, don't run away from problems, like "this system always air locks when you fill it it" like a bad doctor
just change the motor head if the valve moves ok, ok 9/10 times :)
No. Change both. Its a ripoff changing the motor and not the body. People dont realise its the body not moving all the way around which stops the motors hitting the microswitch.
Fit a new head and wiggle the body, sure its going to work until you collect the money..
Reply to Changing 3 Port Valve On Bungs in the Plumbing Jobs | The Job-board area at PlumbersForums.net
