Discuss CH pipes under ground in the Plumbing Jobs | The Job-board area at PlumbersForums.net
H
h4den1
im looking to replace an oil fired boiler, i will be installing an external boiler, in an ideal world i wld like to place the boiler about 5m away from the house,
can i run the pipes under ground etc , i have looked it up and it looks like it can be done, but im after regulations etc
cheers john
ive seen CH below ground before, they are in a duct and well insulated
Hi Yes but insulation and the water proofing of same is of prime concern. Either a duct or Say 2x150mm soil pipe to accommodate flow and return packed with good quality insulation with pipe in centre. Good luck
Reply to CH pipes under ground in the Plumbing Jobs | The Job-board area at PlumbersForums.net
