Discuss Central heating pipes 'banging/knocking' in the Plumbing Jobs | The Job-board area at PlumbersForums.net
C
callum84
I am looking for some guidance regarding a problem that has developed with my central heating system.
A couple of days ago, the pipework started banging/knocking when the heating was going on and when it is cooling down, this banging can vary from a large thud to a series of regular bangs, the later usually when cooling down which then becomes less and less frequent until it stops - this has just started to happen, we have had the property for 3 weeks and was working with no banging etc until around 3 days ago.
Its an alpha combi boiler with radiators/heated towel radiators the radiators have thermostatic control valves (apart from one which doesnt)
I was wondering if anyone had a view/suggestion on what this could be before I have to call out a plumber/CH engineer.
I have looked online at things like, boiler pressure, pipes not properly clipped, air trap?!? All very confusing to me to be honest.
The boiler was installed in Jan 2011, and has a 5 year guarantee, I am unsure if new pipework would have been installed at the same point.
The crawl space sub floor is only approx 500mm so I am hoping it can be rectified without having to lift carpets etc, especially as some floors are tiled.
Regards,
Callum
I assume you have checked system pressure and have bled all radiators.
Open up all thermostatic radiator valves (TRV's) fully and try that.
Thanks GrahamM.
I am going home tonight to bleed the radiators, the banging seems to be situated at the opposite end of my property to where the boiler is, I think I will bleed those radiators first??
If a TRV in say a bedroom is set less than the bedroom next to it, can that cause issues??
Just bled radiators, only water came out no air, boiler pressure sitting at 0.75 bar?? Slightly below what it should be I think? Anyone have any suggestions?
Is the low pressure contributing to the noise in your opinion?
I apologise if this is a basic question, but should rads heat from top to bottom or bottom to top?
The rad in the room I think most of the noise is in heated from the top an generally worked down the rad to the bottom? Is this normal?
Top system pressure upto 1-1.5 bar, open up all TRV's fully & run system to temperature.
Did you try this?
possible solutions
1. radiator valves are not shutting properly and causing banging, try taking head off and making sure valve is loose
2. Pipes need clipping down, try to find exactly where noise is coming from and check under floor for loose pipes
3. noise reducer can help get rid of noises, this can be added to system via tank in loft or radiator
4. Powerflush, system might be dirt ridden and banging
Finnaly try to think of anything that you have done in last few days, turning heating on? turned radiator valve off? pressed any buttons
No it is TRVs at the bottom of the radiator.
Havnt tried to change the pressure, really wouldn't know where to start I am afraid. I hav bitten the bullet and arranged a service for Friday (boiler was installed jan 2011 and has not been service yet.
Nothing different last few days jase158, tried system again tonight, but set boiler to a lower temperature, the noises didn't seem to be as bad although were still apparent?
you need to let engineer know of this problem as it wont be picked up on a service
no its not the flow direction to the trv sounds wrong ask ur gsr guy to check it out . get the pros in its not worth ****ing about with .
I will highlight the noise issue etc yes, i explained it on the phone to another guy when booked service(not sure if was qualified) they said it could be 'normal' expansion/contraction with the pipe work, it just sounds to 'rough' to be normal in my humble opinion, but we will see.
I just hope that it doesn't mean lifting all the floor finishes to get a look at the pipe work, would be a hell of an amount I work to be honest ie lifting plywood/hard wood flooring (kitchen) laminate (hall) and carpets (bedrooms) but I suppose if needs must, or maybe the plumber will have some tricks of the trade to dingoes any issue.
Thanks for the info guys, much appreciated, great forum!!
No issues with the hot tap (tempting fate saying that!) just seems to be the pipe work/rad(s) at the opposite end of the bungalow from the boiler. Especially apparent in the bedroom where the rad heats up from top to bottom. (TRVs at bottom) I have read conflicting views on if this is the rad heating up properly or not.
The rads heating from top to bottom is normal.
Your issue I believe is either:
1. pressure/air related
2. TRV's on wrong end
3. Pipes poorly secured
4. Blockage/restriction
or a combination of above.
phpaul's reply sounds most likely.The next time you hear it go to the rad your hearing most noise and turn the trv fully off.Let us know if this stops the noise.
Thanks guys, I will try turning the TRV off in the offending area as suggested.
GrahamM, can you explain abit further when you say TRVs on the wrong end?
The 4 suggestions you gave, would they just 'suddenly happen' or get worse so to speak? Its just that as far as I can remember last week there was not any issues or they were less apparent, it seems to have got worse all of a sudden?
Speaking to a guy at work, he said he had similar issues but it was because he had renewed the floor finish in his kitchen, to laminate, and that the new laminate was cut too tight round the central heating pipes that come from the wall mounted boiler, and that was causing an issue of noise with the pipes at the other end of his property.
I dont really know if this is similar in my opinion, as would seen strange the floor finish resting against the CH pipes before they go under the floor could cause pipework noise at the other end of the building.
I would have thought if it was an issue, it would be localised to the area the new flooring had been put down in, but maybe not?
I havnt put down a new floor but just thought I would throw that idea in and see what you guys thought? Or if he was maybe pulling my leg so to speak!
turn on heating hold the pipes into rad . does the one with the trv on heatup first ? look at the trv is there an arrow on the body of the trv to indicate direction of flow does the arrow point to the cooler pipe
Thanks phpaul for constructive input, I will try that this evening.
Next on the list mate, are you offering to perform it? :crazy:
Just trying to be helpful!
A woman in Lower Sodbury reported a similar problem - turned out to be a BG fitter who had got stuck in the cupboard under the stairs when doing a gas-check ... been there ten days, and no one had missed him!
Seriously now ... I once had this problem and it was expansion and contraction of a pipe that was tight on a joist.
But then why would it suddenly start out of the blue?
If no work has been done in and around the house, then maybe a joist has moved slightly for some reason, settlement perhaps, or possibly has become damp and has swollen - it would only take a tiny amount of movement.
If the knocking only occurs when the system is heating up, or cooling down, it's worth checking out. First step being to try and pin-point the area the sound is coming from. Try using a tube or a pipe put to your ear on any suspect areas.
Might also be worth running the heating on very low temperature to see if the knocking doesn't happen then.
We did have a carpet laid about a week ago in the Bedroom, but I didnt think that would have caused an issue? Ie there wasnt excessive banging but Maybe it has?
If they nailed down new carpet grips, they may have tightened up a board, or even caused a slight shift in a joist.
If the pipe was tight before, then just a fraction of a millimeter could make the difference.
The floor can act as a sound board, and it's surprising how much noise can be created by such a simple thing.
Glenno1: No the grippers were gown originally and were re-used.
Can such a thing like the grippers/laminate touching the pipework (as per my previous post) above floor level cause knocking/pinging noises??
I would have to go home and check what kind of valve.
The noise doesnt seem to be coming from the TRVs or radiator, more in the floor leading up to the rad??
There is sometimes a 'thump' aswell as the rhythmic knocking/pinging, which could resemble the noise of a valve but again seems to be under the floor.
My suggestion would firstly be to turn the valve when the heating is on and see if noise comes and goes
Have you tried pin-pointing where the noise is coming from by using a pipe or a tube to your ear.
If the grippers were already down, could they have added some nails to firm them up?
If this noise is being caused by expansion/contraction just below a board, you should be able pin-point the spot by using a tube to your ear.
Does closing both radiator valves make any difference?
Reply to Central heating pipes 'banging/knocking' in the Plumbing Jobs | The Job-board area at PlumbersForums.net
