Discuss Cast iron soil stack replacement in the Plumbing Jobs | The Job-board area at PlumbersForums.net
M
messimagician
The main cast iron soil stack runs up the wall with a single T that goes off to the toilet, the pipe then goes through the garage roof and vents about a meter above the roof line.
The bath and sink waste go to a smaller separate soil pipe which is about the same size as the rain water downpipe but I would like to join both of these to the main stack instead and have the smaller soil pipe removed, would this involve major works with the drain or can this be just filled in where the pipe was?
Also can you mix solvent weld with push fit on the main stack or do you have to pick one or the other? Which is the best to use
The smaller soil pipe you mention will be rainwater down pipe with a hopper on top and may join via a gully to your sewer or it may head off to a soakaway.
I'd advise against trying to connect plastic of either type into cast iron. If your dead set on removing the hopper and down pipe then the best bet would be to replace the whole cast iron stack with a new plastic one.
Reply to Cast iron soil stack replacement in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi, Can anyone advise as to why the cold water to my bathroom keeps airlocking? This originally happened about 12 months ago and has happened 3-4 times since. Itā€™s an upstairs bathroom, fed from a tank in the attic. The tank is about 8 Meters away and feeds a bath, sink and toilet. The tank...
Hello all, Iā€™m replacing a concrete paving slab patio in the back yard. The original patio used 50mm deep concrete slabs on hardcore & sand. Iā€™m planning to pour a 100mm deep concrete patio on 100mm hardcore. In order to achieve the same final height to line up with the rest of the patio, I...
