Discuss capping off shower outlet on bath taps in the Plumbing Jobs | The Job-board area at PlumbersForums.net
T
tbxr
Hi guys,
stupid question but just wanted to check but would fitting a
½" blank nut be the best way to cap off shower attachment on bath taps? i've seen it done with a nut and 5p but trying to do it neater as I have about 50 to do.
Cheers
I did wonder if it was an L8 issue, or if it was to do with damaging baths. Thanks
Reply to capping off shower outlet on bath taps in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I'm having a nightmare trying to find matt black wall or deck mounted bath mixer taps with 3/4 fitting that work on 0.2 bar. From tank to tap, I have around 2.4 metres, so a pressure of a little over 0.2 bar. The flow measured from the tap currently fitted is 11 litres per minute. Pretty much...
Hi, I hope someone can help. I’m hoping this isn’t a permanent problem. We’ve converted a gravity vented hot water system, into an unvented indirect hot water system to improve pressure in the house. The previous cylinders are in the loft now they’re in the garage next to the boiler. We...
I need to cap off a water connection which is the water pipe connector to an M15 hose pipe from a kitchen sprayer tap. I have included images so you can understand my problem. Can anyone tell me the best way to blank off that pipe. (That's the vertical brass pipe in the photos)
Hi, I was hoping someone might be able to help with this. The tap is a Bristan RS BAS C, the hot tap has been leaking and I've trying to get the tap off to clean the cartridges, but cant get the sphere at the end off there. Looking at the diagram, it seems that you should be able to pop the...
Hi all, My partner and I recently bought a house and have been attempting to make the bathroom less fugly. I was removing the bath and shower taps to replace, but while removing the bath spout (which had no nut to undo), the threaded section of the pipe broke. I thought the bit that broke must...
