Discuss Can anyone identify the make of this trv? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Does anyone know what make this trv is? Have a few not working and I'm looking for replacements.
Cheers
Unfortunately not new heads are m30 x 1.5. I think the old one's are m28 x 1, so I might have to buy adapters or drain down and change the valve body as well
For the time you will waste running around just replace the complete valve.
Even if a new head fits, if it's not identical, you may find that the temperature settings are far out. I've seen heads, when put on the wrong bodies, give a reasonable temperature when set somewhere between 0 and 1.
Reply to Can anyone identify the make of this trv? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Afternoon all, I have a customer with a heavily extended semi which now has 4 beds, 2 bathroom and 5 reception rooms. They have started working from home and want to zone the heating system, unfortunately the system boiler and cylinder is in the garage with 2 x 22mm primary pipes disappearing...
This is from around 2010. It's got a cross-hatched border with a floral motif. Can anyone identify it pls? Need to replace some of the the pivot-related parts... Cheers.
Hi , I'm wondering whether anybody can help me at all ? My boiler has started making noises which I am unable to identify. If anybody is able to guide me to the route of the issue itll be massively appreciated. I'm looking for an idea of how much it will cost to get it repaired. The water has...
Hi I am trying to fit a Hive Radiator valve into my existing TRV valve body to make them automatic so have bought a Hive valve to try it out. I have done this before in another install but the valves were Danfoss and directly compatible with Hive. I am looking for an adapter that will be able...
