Discuss Broken bath overflow in the Bathrooms, Showers and Wetrooms area at UKPlumbersForums.co.uk.
  1. jaylockwood1978
    jaylockwood1978 New Member
    hi,
    We noticed a leak in our living room tonight after bathing our little boy. But if investigation and noticed the overflow pipe seems to have split and so waste water is pouring out of where the pipe attaches to the plug.
    It’s the tightest if spaces (can just about get my arm under) and it seems as though the pipe has split rather than just come off.
    Any idea if I can just fit a new pipe? The existing part that fits onto the plug seems to sealed/masticked on so god knows how to get that off.
    It’s really tight so reluctant to try and replace the whole unit as it might cause more leaks by disturbing the trap etc. I’ve attsched a photo and any help would be massively appreciated :)
  2. jaylockwood1978
  3. ShaunCorbs
    Yes you can and the other end should just pull off
    The hardest part is replacing the tube at the overflow end
    • Agree Agree x 1
  4. Best
    Best Trusted Plumber
    Looks a fair bit of space there, so shouldn’t be too difficult.
    But we plumbers are used to working in tight spaces.
    The flexi overflow could be cut off carefully. The long remaining part might reach to reconnect on, but if not, then needs replaced.
    • Agree Agree x 1
  5. Best
    One warning is to be careful about the fibreglass that is on base of bath, because it is literally like needles and will get below the skin
    • Agree Agree x 1
  6. JCplumb
    JCplumb Plumber
    That looks like plumbers mait stuck all over, should be able to just rub it off, it's a bit like putty.
  7. Matchless.plumb
    Matchless.plumb Trusted Plumber GSR
    I don’t like thise type of bath overflow . these are not great at all. I’d replace the whole lot and get something more decent
  8. ShaunCorbs
    As in ?????
  9. king of pipes
    Replace the whole lot with a new bath waste and overflow , as above beware of the fibreglass material under the bath there are plenty of wastes to choose from on our sponsor victorian plumbings site . cheers kop
    • Like Like x 1
  10. jaylockwood1978
    Thank you, I’ll keep that in mind about the fibre glass! You pro plumbers must have inspecter gadget type arms if you think that’s a lot of room :)
    Probably a stupid question, but can I replace the waste without actually getting to the back of the bath? It’s compketkt boxed/tiled in so only way would be to demolish all of that.
  11. jaylockwood1978
    This is the bath as it is
    • Agree Agree x 1
  12. king of pipes
    Your a bit screwed there mate your only chance is trying a repair on the what you have , or that bath will have to come out . kop
    • Agree Agree x 4
  13. ShaunCorbs
    Or ask mr tickles :D
    • Funny Funny x 1
  14. jaylockwood1978
    Thought as much, it was like this when we bought the house. Fingers crossed :) I might try and squeeze my skinny nephew in the gap!!
    Thanks for all the replies, much appreciated
    • Like Like x 2
Loading...
Similar Threads - Broken bath overflow Forum Date
Broken cream basin update Plumbers Arms May 24, 2018
radiator in bathroom Plumbing Forum Thursday at 10:33 AM
