Discuss Brittle cold mains pipe from 70's in the Plumbing Jobs | The Job-board area at PlumbersForums.net
R
rjm84
Hi, I've got to go to a job where builder has snapped the cold the cold mains, he described it as bieng plastic , and snapped at the slightest touch , I know what he's on about as I have done the same , I've only encountered it once , I believe was used in the 70's, but need to get a fitting but can't for the life of me think of it ,, octo keeps springing to mind????
im sure it's a glued fitting , anyone know what I'm talking about ?
It was used a lot in the 70s when Rhodesia caused a copper shortage. Yes it can be glued Think the proper way to glue it is with a glue called tangent. It can take upto 24 hours to cure and you also have to use a solvent cleaner before gluing. I have used solvent weld quickset before needed to get water back on rapid,s and it did work so your choice.
Do you remember what the name of it is? And I take it there's ni speed fit alternative
Lots of durapipe down this way. You can get a quick setting glue called Wet-R-Dry that works with it.
Compression to copper couplers available from Pts. Polyorc we call it. About 16mm in diameter?
durapipe abs is what they used around by me. Its still sold and available at most bss and pipecenters. Its about 16mm external but it will be an imperial size.
Polyyork was used around the country aswell, yorkshire make a compression fitting for this i think.
if you go into the local pipe center of the property they will probably have the fittings required and some glue thats takes a couple of hours to set. (not normal solvent weld) take some of the pipe with you if possible.
i think your from around my way. Pipecenter halesowen def sell durapipe and will know what your after if you have no luck else where.
Reply to Brittle cold mains pipe from 70's in the Plumbing Jobs | The Job-board area at PlumbersForums.net
This issue arose about a year ago. Does anyone have an idea why I occasionally hear (about once every hour or longer) a hammer related noise coming from my copper water pipes when no water is being used? It basically sounds like the noise you hear after the water shuts off when your toilet bowl...
Hello. I hope someone here has the expertise to help. I know exactly what situation it took awhile. On the loft on the 6th floor there is a cold water tank this tank feeds six properties in a straight line below my property is on the third floor so in the middle. The job would entail...
Hello there, I have quite a story and a looking for some advice here. On Thursday during the cold snap our hot water stopped working (in the sense of not water at all coming out of the taps). The central heating was working fine. As I have two newborns and having encountered this for the very...
1K
Hi I fitted a bath/shower 12 years ago and a few months ago it developed a leak. It was basically at a coupler on 40mm solvent where my new white PVC joined the existing grey PVC. I cut a hole in the ceiling and could also easily view it with the bath panel off but not access it from there...
2K
Hello all. I've just joined, was going to post in the new members forum, but the first site generated email sent me here... I am here, as have a challenging and interesting problem, which I'll try as best to describe below keeping to the point and as short as possible, to avoid boring any of...
3K
