Discuss Bristan Push Bath Waste in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Advice please. The overflow/control on the Bristan push up waste (W BTH PU1 C Bristan Luxury Bath Pop Up Waste & Brass Plug) has become loose which, in turn, has caused the push on overflow pipe to detach from the back of the fitting. I thought that loosening the control knob and re-sealing the back of the fitting would be an easy job even for an amateur!! I was wrong. I cannot get the control knob off the spindle. I have loosened the screw and saturated the inside of the knob with WD40. It will not shift.
Are there any other tricks of the trade that I could try? If I have to replace the the whole thing any tips on getting the old unit off so that I do not damage the bath? Many thanks.
Edit:
I worked out what the problem was and some careful tactile engineering produced some movement that I exploited with 2 screwdrivers. DH is now 'complaining' about the smell of WD40 and silicon sealant in the bathroom.
Reply to Bristan Push Bath Waste in the Plumbing Jobs | The Job-board area at PlumbersForums.net
IS IT POSSIBLE TO ADJUST THIS MIXER UNIT? WE HAVE TO HAVE IT TURNED ALMOST FULLY ANTI CLOCKWISE TO GET HOT WATEROUT. THE FRONT PLATE WITH MIRA ON IT PRISES OFF AND INSIDE THERE ARE SOME PLASTIC BITS AND A SMALL CROSS-HEAD SCREW IN THE MIDDLE. THANKS
