Discuss Bosch Greenstar 27CDI losing pressure in the Plumbing Jobs | The Job-board area at PlumbersForums.net
A
albapa
Hi all,
We have Bosch Greenstar 27CDI Combi that is losing pressure at an alarming rate. After filling the system to 1.5 bar, it loses it in about 30 minutes. There is also a sound of running water at the bottom of the boiler. If I switch off the boiler, the sound stops. No obvious leak anywhere. No water coming out from the PRV pipe. I couldn't check the condensate pipe because it's plumbed in to the drain.
Shall I test the boiler by filling it up and then isolating it?
Maybe open up the condensate pipe and check if water goes out there?
The sound of the running water makes me think it could be the heat exchanger, as the mains water runs through a leak and leaves via the condensate pipe.
I'd be grateful for any advice.
Albert
tbh best to call a gas safe eng out
Reply to Bosch Greenstar 27CDI losing pressure in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi, Boiler is losing pressure, from 1.5 bar to 0 bar in about 4 hours. Have checked all rads and seem to be fine, no water out external prv pipe. If the heat exchanger is faulty what do I need to look for? There is a constant run of water from the condensate pipe when heating on but not sure...
Hi, Looking to see if anyone can give some advice please. My Baxi boiler has been losing pressure and I am having to top it up approx. every 4 hours from 0-1.5 bar each time. This has been going on a week now. I have also started to notice small drips running down my condensate pipe...
Just had a new Worcester Bosch Greenstar 30Ri fitted with the magnetic filter. When the system is running the boiler is so quiet but there is a sound of trickling water through the filter, loud enough to hear quite clearly and is pretty annoying. I wouldn't of thought trapped air would sound...
Can central heating / gas engineer expert help me with below issue. During winter time only, I have been having issue with low pressure or pressure dropping with unvented hot water cylinder system. During summer time there is no usage of central heating so the pressure at unvented system is not...
Hi all not a plumber but am an engineer I have pressure drop in the system Worcester Bosch came back after repressureising the expansion vessel and he replaced the heat exchanger element. The boiler is coming up for 15 years old. The boiler was going below one bar and not increasing when...
