Discuss Bolier Running Question in the Plumbing Jobs | The Job-board area at PlumbersForums.net
A
alig31
Hi all,
I will be fitting new radiators all round the house when it warms up a bit more and I can convince my missus to turn the heating off. Can I run a combi boiler (for hot water taps) with no water in the central heating system. Obviously wont be using the heating but was wondering if I needed to fill the heating if the boiler was needed for showers etc.
Thanks in advance
Regards
Al
make make and model of boiler do you have?
I might set up a short loop then, 1 radiator and return. Cap off after 1st radiator
regards Al
Reply to Bolier Running Question in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Last May had a new Greenstar 4000 boiler fitted and only recently started using the heating. Once the set room temperature is reached the boiler modulates (presumably) and stays running for very long periods (many hours) but the circulating water is only luke warm (about 35 degrees) Any heating...
T
Hi We urgently need to get our h/w cylinder replaced because it's leaking. Our current system is oil boiler feeding underfloor downstairs, radiators upstairs and an unvented hot water cylinder for hot water. We are thinking of moving to a heat pump at some point but aren't ready to do this. My...
Free running radiator change. I currently have 1 radiator free running with all of the others fitted with TRV's. Problem is that the free running radiator is in the porch and I'd rather not pay to waste heat there. Question is will it be ok to close this radiator off and ensure that one of the...
Baxi 600 central heating is set at minimum the radiator symbol on the boiler is flashing. (asking for heat .fan is still running ) this is like this all day is this correct before I call out engineer there are no other controls ie time lock or room stat on system
Can central heating / gas engineer expert help me with below issue. During winter time only, I have been having issue with low pressure or pressure dropping with unvented hot water cylinder system. During summer time there is no usage of central heating so the pressure at unvented system is not...
