Discuss Boiler sizing in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hobo128
Can anyone recommend me a boiler sizing app. Got a huge house with loads of rads 4 bathroom, ufh and a 250 litre hot water cylinder. Can't find any decent apps to make it easy to size up
dont whole house size it either by mears calculator or mr combi heat loss calc
will take time but room by room
and cylinder sounds a bit small
and make sure mains are up to it if you have 4 folk in showers at the same time, just done this recently and ended up with a small booster set
[DLMURL]http://copperplumbing.org.uk/sites/default/files/content_attachments/pipe-sizing-basic-principles.pdf[/DLMURL]
Reply to Boiler sizing in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Ive got a new replacement boiler to install and the Energy Saving Trust whole house boiler sizing is no longer being allowed to be used to correctly size new boilers. Apparently there is an app you can use for room by room calculation anyone with a link. I've looked online and keep just...
Hello want to know on how do you calculate size of expansion tank for closed heating systems . for example 500 meters of 16mm underfloor heating and 4 double ~1000mm radiators , hot water cylinder coil , and oil boiler
Does anyone have a favorite rad sizing app or site? I've used a few but they seen to vary and many are quite clunky. Any out there with decent accuracy, a whole house report would be amazing too...
Hi all. I've currently got a system boiler with cylinder and rads on s-plan. I'm planning on installing UFH in my kitchen/diner and utility/downstairs loo. My question is around mixing valves and opentherm. Do mixing valves dynamically adjust the amount of cold being mixed in response to the...
Hi All, We have finally decided after a bit of a persuasion to have installed a utility room in our garage that currently houses our oil boiler. Initially we thought the boiler may stay in place but after discussions with the builder we would have to move the boiler to replace the floor and...
