Discuss Boiler size in the Plumbing Jobs | The Job-board area at PlumbersForums.net
C
Cchrish0
Hi all. Wondering if any one can help out. We are having a new grant external blue combi fitted on a project we are working on. The total rad kW is about 12000. There is one main bathroom with poss combi fed shower. An on suite with Elec shower, downstairs toilet and kitchen. Engineer is planning on fitting a 21 kW model. My concern is this may be a little small. Any advice would be great.
Normally combis are sized on hot water not heating but don't know if that's the same for oil
I'm not sure they even do a 21KW combi?? might be wrong but I thought the smallest was 24KW.
Need to discuss it with installer as said before.
Discuss litres per minute of hot water and how many people live there that kind of thing.
I'd get a second opinion from someone who' s seen the job too. Before you go ahead. It will put your mind at ease
Reply to Boiler size in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi all, I have a wallstar combi oil fired boiler. We got low on oil a couple of weeks ago but didn't run out. Since we've had our oil delivered the boiler won't fire up when hot taps are turned on so no hot water. The boiler fires up periodically to heat water but not when we turn on taps. I...
I have a Grant Vortex Blue 26kw external oil boiler, installed less than 12 months ago. It's had intermittent non-starting problems resulting in multiple warranty visits, part replacements and eventually burner replacement. The replaced burner I discovered was a 'yellow flame' one, apparently...
Hi all, I have a combi boiler for hot water and heating but have 2 showers in the house. Obviously low water pressure if both showers are used at same time. I'm wondering if I could install a water tank to gravity feed one of the showers, with new electrric shower and if so how to stop the water...
PLUMBING ADVICE NEEDED Combi boiler in our house, downstairs water seems to be piping hot. Upstairs basin, bath and shower only ever seems to be lukewarm - so much so that no one even wants to bath as it never gets hot enough! Open to suggestions as to what it might be and if anyone can...
T
Please advise me. I am a disabled pensioner. I had a wet room fitted just over a year ago using a local authority grant. Builder was employed by local authority. I had no say in who carried out the work. I have called the builder out under the guarantee several times for water leaks. The shower...
TheCatWhoNeedsaHotShower
T
