Discuss Boiler/hot water tank in the Fittings & Pipes area at UKPlumbersForums.co.uk.
Thread Status:
  1. Simone
    Simone New Member
    Hi, had water slowly dripping out of this top pipe which goes from boiler to hot water tank, (top one in the picture)does this union just need tightening or is it a bit more serious than that, just had the hot water tank heat up and this top pipe has stopped dripping probably due to it heating up, any ideas.? Thanks
  2. Chalked
    Chalked Plumber GSR
    Hi
    It's an old safety valve. Please don't try to tighten it up, that may make it leak more!
    TBH it needs replacing with a newer better one.
  3. Simone
    Simone New Member
    Hi, thanks, if I were to replace it like for like would it be an easy job.??
  4. ShaunCorbs
    You would have to drain the system but should be a straight swap (the whole valve)
Loading...
Similar Threads - Boiler water tank Forum Date
Cold water tank in a flat with a combination boiler?? Plumbing Forum Jul 8, 2018
Boiler not registering a hot water tap being turned on. Plumbing Forum Monday at 9:51 AM
Thread Status:
