Discuss Boiler changes, Boiler servicing or both? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
T
tim88
hi all
Just needed a bit of advice.
As a newly qualified gas safe engineer is it a good idea to concentrate on doing Boiler replacements or Boiler servicing and maintenance or both?
cheers
Tim
Just concentrate on what is within your comfort zone.
It is very easy, when newly qualified to get out of your depth. Get on a few manufacturers days to see how individual boilers operate etc. also the baxi fault finding course is very good as well.
Graham
Really you need to do both as both help with each other.
I started off installing through my apprenticeship for 4 years then went service and maintenance for 2 years.
After that I have gone through a few years and have settled with service and maintenance but there are things if you have installed the boilers know off the top of your head instead of scratching your head the same the other way round.
I would concentrate on building a sound customer base before being picky about what you do. You can't turn work down. For eg. If you choose repair and you go to a customer to find their appliance faulty and beyond repair, what do you say? "you need a new boiler/fire, find someone in the yellow pages to fit one cos I don't install them" I don't think so.
If I could have my time again I'd get into servicing and breakdowns. I'm 32 and have the back and knees of an 80 year old. Installing is more involved and great job satisfaction but it catches up with you.
we would all like to specialise but as someone has said its not that easy given a choice id do nothing but breakdowns once youve been doing 4 a day foor a couple of years it wil lbe easy as youll more of less know what the problem is likley to be before you take the case of
actually id like to specialise in ballvalves 4 a day would be good
Hi, I really only install, do the odd break down for my regular customers, but I do have a very good working relationship with a local service engineer, who is only really interested in servicing, so I pass on all new/ tricky break downs and all my servicing to him, and likewise he passes all installs on to me, when he gets a boiler beyond repair I stick in a new one! but as stated earlier you need to work in your comfort zone(then build on that) and work on good customer relations!!
Reply to Boiler changes, Boiler servicing or both? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi All, what's the cost of a service for an unvented system ? (valiant boiler & mega flow cylinder). I was charged £320.00, for the following: Boiler service - no parts changed. Change wireless thermostat (honeywell to Tado), I supplied the thermostat starter kit. is that about correct ? Also...
Just had a new worcester bosch. 1000 combi boiler to replace 18yr old vokera. No problems with new boiler. Enquiring about yearly maintenance / safety check and service i £19.00. per month, £228 one off yearly payment. It includes parts and labour if needed. As new boiler is under warranty...
My first post here, looking for some advice. I've just had my boiler replaced with a worcester 4000 combi boiler. The engineer put chemical flush and inhibitor in when filling up, ran the raditors hot and then tested using a strip. And has left both in saying this is safe, and standard...
1K
My daughter lives alone in a 3 bed semi in the west country. The house is 20 years old. The central heating and hot water are provided from a Glow-worm gas boiler working in conjunction with a Boilermate 2000. The central heating pipework is microbore. In view of the age of the boiler and...
Hi everyone! Parents not used the boiler since 2013/2014, since installing a new wetroom for them they have now decided its worth getting the boiler running again. The only reason it has not been used i so long is the the zone valve kept getting stuck (would have fixed this myself if i knew!)...
