Discuss Boiler change in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Strangebrew
Hi there
I,m looking to change my gas boiler which is presently a Glow Worm Economy 40 with a high efficiency combi boiler.
I am located in Mansfield Nottinghamshire: NG18
Cheers Andy
Thank you for placing you work requirement on the forums
Any members who may be able to assist ,please contact op direct
Reply to Boiler change in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi I have a Glow-worm back boiler which is giving me grief (I would have upgraded it by now but its a listed building and there's issues with venting through the external wall and I'm reluctant to go with an electric boiler instead (because of the consumption cost)). It's a sealed system. The...
Hi. I believe this boiler can be changed to a system or combi. Does this mean the hot and cold tails have to be blanked off?? Also the horizontal flue does not come with self tappers compared to another brands I've installed in the past.. Im I right in saying it's almost like a pushfit? The...
I currently have a Vaillant ecoTEC Plus 438 system boiler which is 13 years old. I have been having problems with the boiler which potentially boils down to the heat exchanger so I am now looking to bite the bullet and have a new boiler installed. My set up at home is that I have a 4-bed...
I am having a new system boiler to replace very old cast iron open vented jobbie. heating engineer has offered an S plan system and a Main eco compact. My understanding is that S plan will return water at too high a temperature for boiler to run efficiently and stops weather compensation.
Podengo
H
Wishing everyone on tgmhis forum a very happy Christmas!! I am working on a combi boiler which has problem with heating only. Water is heating normally. Here are the symptoms 1. Signal from thermostat is not firing the boiler. It does not make any sound when heating is on from thermostat. 2...
