Discuss Bird can fly into chimney serving open-vented gas fire! in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Ric2013
Is it usually considered acceptable for an open-vented gas fire (by which I mean one which vents its exhaust gases up a chimney by natural draught) to have a terminal that will allow a bird into the chimney?
Got a phone call from my mother yesterday. She's not going to be able to meet me after all because a bird has flown down the chimney and she wants to try to get it out. In the end, it got itself out - she couldn't access the chimney anyway because the fire is a gas fire. It is a standalone gas fire, fake coal effect thing (the boiler is a separate item, in a different room).
While she is going to have the heating and gas system inspected and, I'd hope, serviced, by a GSR, I just wanted to know if, mentioning no model numbers or codes, it is usual for an open vented gas fire that uses an old chimney (presumably lined) to have a flue termination that is so open that a bird can get in.
My hunch is that this it likely to be considered an unsafe installation.
Can GSRs please give a general opinion as if the install gets an all-clear, I'm going to need to talk my mother into getting a second opinion.
Hope this query is general enough not to breach UKPF policies? I've done my best... hope it's good enough.
Many thanks,
R
Hi, yes it is quite usual, In my time servicing fires I have found a few dead birds at the back of fires. It is not a safety issue and the installation is not deemed unsafe unless the chimney is in a poor condition. Or fails the flue tests. You can by a balloon to fit in the chimney pot to stop it happening again.
All gas fires using chimneys should have a suitable terminal fitted.
Agreed and one of the suitable terminals is considered to be the original old style open chimney pot, but without a gas approved balloon, cage, basket or whatever you want to call it fitted to the terminal it wont stop birds from ocasionally getting down the flue.
Reply to Bird can fly into chimney serving open-vented gas fire! in the Plumbing Jobs | The Job-board area at PlumbersForums.net
