Discuss Best place for end feed or capillary fittings in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Do you need to buy in bulk ? just means you have loads of stock sitting around, unless you have a high volume of work its not always worth the outlay.
I use the Stanley storage box's and find they hold enough for every day use (common fittings 15 & 22) if you get the deep case its surprising how meny they hold, larger jobs just buy extra as needed, and you don't save that much buying in bulk, + you tend to loose quite a lot rolling around in the vanI just thought it would work out cheaper to buy in bulk and I would not have to keep going to merchants for just 1 item
its awkward when there is no local merchant where your working
Ive been doing some book work today and I have found Williams not cheap at all. Local builders merchants that we use for example are 25% cheaper in the same month for everyday material such as pipe and fittings I was surprised today when I looked and found that screwfix are ÂŁ20 cheaper for a pack copperTry Williams, not always the cheapest though!
Isn’t there copper thin though?Ive been doing some book work today and I have found Williams not cheap at all. Local builders merchants that we use for example are 25% cheaper in the same month for everyday material such as pipe and fittings I was surprised today when I looked and found that screwfix are £20 cheaper for a pack copper
Compression I agree entirely but there's not much in it with end feedYes. But I prefer the brand with the same name where you are from.
TrueCompression I agree entirely but there's not much in it with end feed
Reply to Best place for end feed or capillary fittings in the Plumbing Jobs | The Job-board area at PlumbersForums.net
