Discuss Best holesaw for stainless steel in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Rybo_1
Evening boys!
Recently been having to drill through stainless steel. 2 x 32mm hole for a set of taps. I've been using my normal Bosch powerchange bits with cobalt pilot bit. I'm barely getting the two holes done from one bit. Drilling on a slow speed setting. So that's working out at £5 a hole. Just wondered if anyone had ever any specialised S/S bits and if you would recommend them. Cheers
you tried it at high speed? think those bits are better at high speed
Slow to Medium speed with oil not wd40 if I remember correctly.
Check out Qmax hole punches you'll get a perfect hole buy a good pilot and some cutting grease and some patience bobs ur mothers brother
you need a hole punch ikea used to give you one with their stainless sink its in two pieces with a bolt through thttp://www.ebay.co.uk/itm/1-1-2-ROUND-HOLE-PUNCH-by-THE-BRITISH-TAP-DIE-CO-Ltd-/291279223192?pt=UK_Collectable_ToolsHasdware_RL&hash=item43d1983998he center you just\ screw the two parts together and it punces a hole
not the size you need
Thanks for responses. I'm pretty sure high speed is a big no no! Have never used cutting oil. Think I might get some for next. Been looking at either starrett or the Lenox ones. I'd be pretty confident with starrrett. Normally unbeatable in the hole saw game
You can get specialised holesaws for stainless steel, and you have to use cutting oil with them.
They are costly, but for kitchen sinks the best thing is a hole punch.
Perfect size hole, no burrs and no risk of slipping and damaging the sink.
Hole Punch | Clas Ohlson
[DLMURL="http://www.ikea.com/gb/en/catalog/products/28512100/"]FIXA 2-piece tool set - IKEA[/DLMURL]
a step drill will leave a burr.
Reply to Best holesaw for stainless steel in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi All, Looking for a bit of advice on the best way to pipe this. - 24kW Worcester regular boiler in kitchen, approx. 9 years old - unvented tank, zone vavles, pump, expansion is on first floor in airing cupboard - Currently piped as S-plan. - Hive controls. - Would like to fit 6-zone...
I have a question that I’m hoping those of you who are experienced central heating engineers may be abler to throw some light on. But first I need to tell you about my system, and the problem I’ve been having. Just over 7years ago I had a new CH system installed in my small semi. I say new – in...
Hi, I have to replace my pressure tank (30 years old, waterlogged) with a new one, Well x Trol 202. This one comes with a 1” stainless steel elbow, to which I will screw the brass T fitting. I have made several brass to brass connections during the years all leak free, but never brass to...
I need to drill out a 32mm hole in a stainless steel bar (4 - 6mm) What is the best type drill bit for a normal combi 18v drill.
5K
Hi everyone, First a quick bit of background : I'm English, living in France, and renovating a 1960s house, which has pretty much needed to be stripped back to the studs, and started again. Full new electrical refit, plumbing refit, walls, ceilings &etc. It took about a year-and-a-half (as...
2K
