Discuss Best Digital Manometer! in the Plumbing Jobs | The Job-board area at PlumbersForums.net
01ST13795
I'm going to bite the bullet and buy a digital manometer, just wondering which is the best on the market; Omnitron, Anton, Testo, Kane? Any others better?
Thanks for any replies
Sam
Digital manometers are great for setting up boilers, but I still think the faithfully water gauge is best for tightness testing; it don't breakdown or need recalibration, other than a flush out and water top up.
On non domestic u may be standing around for 90 mins with u gauge tho/ reading other threads?
u
Completely agree. I always use my j gauge for tightness tests except when the installation is huge. Like the 23m3 job I found a few weeks ago.
Agree with regman entirely, I use my Anton v2 for setting up and checking boilers but use a rothenberger manometer for TT etc.
Done commercial industrial. Never had one this length of time. It is a badly designed gas install for the regular commercial guys, if you have a 90 minute tightness test. Sectional isolation with purge points will always simplify testing and purging.
Maximum ttd is 60 mins according to table b13.
Type of Gauge Typical Range(mbar) Typical Readable Movement(GRM) (mbar) Typical MaximumTTD (Mins)
Water (SG 1.0) 0 - 120 0.5 30
High SG (SG 1.99) 0 - 200 1 45
Electronic (1 decimal place) 0 - 200 0.5 30
Electronic (2 decimal places) 0 - 200 0.1 15
Electronic (1 decimal place) 0 - 2,000 0.5 30
Electronic (No decimal place) 0 - 20,000 5 60
Mercury (SG 13.5) 0 - 1,000 7 60
Was a biggie. No gas line diagram. Spent a day tracing, measuring, inspecting and testing that job.
Service riser full of "stuff", helpful FM staff and lots of locked doors ??
You have been reading IGE/UP/1 have you not?
Its madness, when you come across gas service installs that serve 200 flats and there is not one sectional isolation valve or purge point. How did they test it and purge it?
Testing isn't an issue if you're using a calibrated digital manometer with 2 decimal places and a gem of 0.1. Brought my test time down from 45 minutes on the j to 4.5minutes.....
Yes I think your spot on.
Reply to Best Digital Manometer! in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi everyone! Parents not used the boiler since 2013/2014, since installing a new wetroom for them they have now decided its worth getting the boiler running again. The only reason it has not been used i so long is the the zone valve kept getting stuck (would have fixed this myself if i knew!)...
Hi All So with my new boiler on the way and to give it the best chance of longevity I am going to install a Scale reducer, we live in a part of the UK with the hardest of water and it trashes most things eventually. I am going to buy a Scalewatcher or a Combimate or maybe even BOTH and was...
Firstly , apologies if this is inappropriate. I'm really not sure what questions I should be asking. I had a bathroom refit done around 7.5 years ago, including a digital shower. It's been great, but recently has really started playing up - the controls to raise or lower the temp seem to make...
2K
Hi all, thank you so much in advance for any help. I’m always really grateful for the advice and support from experts when I have been on here a few years ago. There’s a dripping coming from my bathroom and I can hear it coming from behind the toilet and I’m worried it’s causing a buildup which...
Hi, I need some urgent advice. I've Just come home after going out for evening, to discover hallway floor and kitchen floor covered in water. On further inspection I discovered that water was coming from boiler cupboard. On looking in boiler cupboard I found boiler has started leaking water...
