  1. Hi, welcome to the new look UKPlumbersForums.co.uk - Login with your usual login details, or sign up if you don't already have an account. If you post just once, all the advertisements get automatically removed. We have some competitions coming soon, and lots of new feaures.
Discuss Best core drill set to buy? in the Plumbing Tools area at UKPlumbersForums.co.uk.
  1. baronwills
    baronwills Guest
    Hey chaps
    What core drill set would you recommend. Didnt want to spend too much if i can help it. The Rothenberger full set is about £140 all in but im open to suggestions if anybody has a better alternative.
    Cheers.
  2. aaronsmith
    aaronsmith Guest
    i have makita cores they are quite good,norton are good too,rottenburger are ok tho:)
  3. Mike Jackson
    Mike Jackson Plumber GSR
    I reckon the best bet is to buy a cheapish set to start with and as you wear the cores out replace with better quality. That way you'll find out which cores you use regularly and not waste money buying an expensive core bit that you'll never use. A coupleof the core bits in the set I've got have never seen the light of day.
  4. Phil
    Phil Plumber
    Makita P-74712 Diamond Core Kit - Makita Direct
    This looks a good price, wish I'd bought this than the premier set from Lawson at the same sort of money.
  5. Muse2k8
    Muse2k8 Guest
    Have you tried the diamond cores from *********? They're a sponsor and I know its all alot of us use now.
  6. winfers
    winfers Guest
    I bought an un branded set costing about £140.00 four years ago. the cores are great but the mandrels are soft and the SDS one actually twisted during coring. I will go for a trusted brand next time.
  7. GQuigley67
    GQuigley67 Trusted Plumber GSR
    I got an unbranded core set from PDM drains and it has served me well, £120. Once individual cores start to wear I am going to replace with one of the brands, hopefully Hilti if they're not too pricey
  8. WHPES
    WHPES Trusted Plumber GSR
    Norton are pretty good value, as are Marcrist.
    The Rothenberger ones are just a rebadged version of one of the two given above for a higher price I believe.
    Hilti are top of the range
    365 drills currently only do small core drills for drilling tiles, and not large masonry ones.
Loading...
Similar Threads - Best core drill Forum Date
Simple q - which isolation valve is best for a bathroom sink / toilet? Plumbing Forum Friday at 10:32 AM
best replacement burner Oil and Solid Fuel Forum Jul 8, 2017
Asbestos cold water tank??? New Member Introductions Jun 12, 2017
Help - Best heating control Plumbers Arms Jun 1, 2017
Best fittings for lead Fittings & Pipes May 29, 2017
Best fixing you have used Plumbers Arms May 19, 2017
Best Blockage clearing Chemical product Plumbing Forum May 18, 2017
  1. top core drill brands
  • Users found this page by searching for:
