Discuss Best blow torch? in the Plumbing Tools area at UKPlumbersForums.co.uk.
  1. hihowudoin
    hihowudoin Guest
    Rothenburger superfire2 + propane for day to day use :)
  2. WHPES
    WHPES Trusted Plumber GSR
    Bullfinch Firepower torch with MAPP cartridge. The Firepower is available either to fit disposable cartridges or refillable Primus cartridges.
  3. Billy Bob Bob
    Billy Bob Bob Guest
    just bought the bullfinch performa seems to be running far to hot on propane its over cooking 15mm,faulty or wrong gas about to ring bullfinch as instructions say to use propane only which i am
  4. SPC
    SPC Plumber GSR
    I have 2 torches, one is the superfire 2 with the standard nozzle which i like using when im soldering 22mm or bigger and the other is the turbotorch which is pictured earlier on in this post which i find is superb for 15mm or soldering in tight spaces where you need a fine controlled flame. propane with both of them is ample. i keep a bottle of mapp with me too tho just for them special occasions where theres some water in the pipe which needs soldering or your trying too get a 30 year old immersion out of a cylinder :D
  5. SPC
    SPC Plumber GSR
    just another point too note the turbotorch has a swivel nozzle so you can point it however you want which can help when your limited with space whereas the superfire 2 isnt
  6. Dan
    Dan Admin
    Just digging up this old blow torch thread.
    What's the best blow torch these days?
    Any of these any good?
    blow torch | eBay
  7. ShaunCorbs
    7-9th down look / are the superfires
  8. sammathias
    sammathias GSR
    All about the turbo torch extreme with standard propane. Forget mapp gas. Ive had superfire 2 in the past but find a turbo torch has a more direct flame...no need to use a heat mat at all!
  9. Vee
    Vee Plumber GSR
    Super fire 2 and Propane adapted to Primus reusable Bottle.
Loading...
Similar Threads - Best blow torch Forum Date
Best way to seal this? Plumbing Forum Sunday at 10:18 AM
Best system boiler???? Oil and Solid Fuel Forum Jul 10, 2018
