Discuss Baxi Combi Boiler 105 HE Losing Pressure & 60 Degree Light Flashing in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Bhavick
I've got a baxi combi boiler 105 he and for the last couple of days the 60 degree light on the boiler keeps flashing and the pressure on the boiler has completely gone down to zero. Am not very technical when it comes to plumbing but i use to unscrew a small screw underneath the boiler that released some pressure and made the pressure go up again for a short period of time but now the 60 degree light is constantly flashing and i don't know what to do or what it could be?
Reply to Baxi Combi Boiler 105 HE Losing Pressure & 60 Degree Light Flashing in the Plumbing Jobs | The Job-board area at PlumbersForums.net
My Grant combi oil boiler is giving me quite a headache at the moment. When I returned home last Friday I'd no heating or hot water. An engineer called the next day and diagnosed a faulty pressure switch. This was changed and everything seemed ok. However then the boiler began to lose pressure...
M
I have a viessman vitodens 222F combi storage boiler on the ground floor. It has 100l capacity inbuilt cylinder which is delivered on mains pressure. I bought it hoping I could have two showers across floors running with hot water even if it’s a short while, while avoiding an unvented...
Max Hill
M
I'll pop this into the general advice forum as it seems the most active, but mods - feel free to move if there's somewhere more appropriate. Thank you! --- Apologies, but yet another "boiler losing pressure" thread - I've read many others, but am no closer... Not my boiler (parents), so...
2K
  • Locked
Looking for some help here - not my boiler, so consider me a proxy. I'm also by no means a heating engineer: I'm just looking for pointers, as the owner of this boiler is now caught firmly between "not us", "not us" and "not us" - nobody will take responsibility, and just calls into question...
Combi boiler system losing pressure every 2 days. We've been topping it up for months now and have had various radiators replaced and flooring pulled up downstairs around each of the radiators but so far no leaks have been found. I'm at a bit of a loss of where the leak can be because given...
1K
