Discuss Bath taps, flexible pipe connector bend/twist ? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
U
uselessplumber
Hi, i'm trying to connect my bath taps but need some advice on length of flexi pipe. Is it buy longer ones and bend like i have in my pictures, or get some smaller ones?
My worry is that if i buy smaller ones because they are 22mm they won't bend onto the tap threads because its pretty stiff? and they are quite a way from centre of bath (pipework)
thanks!
Be fine with the longer on
Be better with rigid copper but longer flexi's will do just no sharp bends or kinks on the flexi
Reply to Bath taps, flexible pipe connector bend/twist ? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi I am trying to replace my bathroom tap with a new one, I am trying to remove the existing rusty flexible tap connectors from this bit of 22mm copper pipe. But this thing is not budging at all its like its welded or super glued on, I am using some water pliers on both points here but its not...
Hi I have a 22mm hot and cold water supply to new bath. The pipes finish with compression valves. I need a 500 mm tap connector hose to connect with half inch thread on the new bath tap. All the connectors at the main plumb merchants are 22mm x 3/4 inch. No one seems able to answer question...
Hello, I have a troublesome fixed 15mm copper pipe with isolation valve going to my toilet fill valve. It's too tight for a Flexi hose. Can I use a push fit tap connector instead which will give me more flexibility in fitting?
Hello, I need some advise, will greatly appreciate if someone can help. My mixer tap is leaking from base want to renew it. However the tap cold/hot water feed is connected via connectors/fittings as shown in attached picture. Can anyone please advise how to disconnect tap from these fittings as...
A
Hi, I am replacing a leaking push fit flexi tap connector under the bath with a compression fitting flexi. The problem is that the old pipe seems to be slightly smaller than 22 mm compression fitting and when I tighten the compression nut the whole fitting is easily sliding off the pipe and...
