Discuss Bath mixer tap problem in the Plumbing Jobs | The Job-board area at PlumbersForums.net
defender1007
Hi. I have a tantadisc 2 hole bath mixer tap with shower attachment that was fitted in 2002. Noticed the cold water tap is getting harder to turn off (stiffer). I suspect it requires a new ceramic cartridge. After extensive internet searching I cannot find any information regarding this tap and spares. Does anyone have any info on these taps?
you should be able to pick up the disks from a plumber merchant but better sill is to replace the compleat tap bodies they are available in 3/4 or 1/2
Reply to Bath mixer tap problem in the Plumbing Jobs | The Job-board area at PlumbersForums.net
How do i replace the quarter turn cartridge on this cooke & lewis ricci bath mixer tap . Normally there is a grub screw somewhere to take the handle off, but for the life of me i cannot find one on this mixer. Any helpful suggestions would be greatfully received.
I have a slow leak in the bath. Its a mixer type set up. I'm unfamiliar with the tap handles and how to access the cartridges etc. If I can work out the product name/brand/type then I can work out how to remove the tap handles (no obvious indices so presuming they pull off some how). Would...
Hi, I can’t get one cartridge to budge when trying to replace in a mixer tap. The hot side cartridge was tight but removed with wrench comfortably, but cold side is so tight Ive burred the nut on the cartridge. Any advice on how else to remove the cartridge without damaging the mixer tap is...
I am trying to replace the cartridge for a waterfall tap (mixer mono) for the bathroom sink, I have run into a problem whereby I cannot remove the cartridge as the usual 32mm nut is recessed and I cannot get to it. The tap is from screwfix ( NIAGARA WATERFALL BASIN MONO MIXER TAP) I have...
I have a bathroom in my first-floor loft conversion. The header tank for the vented boiler is located as high as possible but the sink tap is just above the head of water so obviously the pump cannot self-start. A momentary activation of the bath tap overcomes the problem but it’s not very...
